I am having a 5900 images project and trying to import my GCPs to the project. The issue I am having is that I do not know where are the GCPs in the pictures. Usually I used a tool that tells you the proposed locations of the GCPs but cannot find this in context capture.
Please advise if that is available.
What kind of GCPs you have? Are these QR codes or simple markings? Contextcapture automatically finds only specific tags. For other markings you will need to provide some manually and then it will tell proposed locations. It is easier if model is at least in same coordinates.
