Finally there is a aerotriangulation positioning mode management with enhanced control for adjustment and rigid registration steps so RTK flight data can now be fully used.
Here are the reports using different aerotriangulation approaches from DJI P4 RTK flight.
Flight: Double grid with angled camera
Reports:
GCP-only: Aerotriangulation only on GCPs. GCP surveyed using RTK/PPK instrument.
RTK-only: Aerotriangulation using RTK only and use GCPs as checkpoints
RTK+GCP: New option in CC U15 using 1 or several ground control points and/or user tie-points constraints and accurate initial photo positions (RTK/PPK)
*opt: Same but keeping existing calibration from good 3D flight improving accuracy.
PDFs:
https://files.fm/u/8pkhs623
Files no longer available. Please could you email them to me at rogerdixon67@gmail.com thanks in advance
Reuploaded - https://files.fm/u/8pkhs623
