error at the beginning of reconstruction
Dear all,
I made the project in CC v10.15.0.21 and something went wrong
I try to calculate usual reconstruction. In Aerotriangulation blog everything was ok. But model fails at the beginning, at 1%.
Maybe somebody knows what's going?I attach .log files
Thank you in advance
test_mx8 - Tile_2.ziptest_mx8 - Tile_1.zip
  • Hi Anastasia,
    Are you using a mask for the input photos?
  • This is an issue that we are aware of. A hotfix is due to be released which will include a resolution to this . The problem is that your mask uses 24-bit (RGB Channel) images but ContextCapture Update 15 currently requires 8-bit only for masks.  In the short term you will need to use a 3rd party application such as IrfanView (https://www.irfanview.com/ ) as a workaround to convert the images from 24-bit to 8-bit.
  • Oh! thank you so much! I will try. I hope this helps, I've already tried everything)
  • Hi Felix,
    I'd used 8-bit masks, but still the reconstruction doesn't count. It goes without them. So the main issue is mask, but I think problem is not in color depth.
    I've used these settings.
    A3DF
    �MQ�깉�d��+��'�5`}i��E������=��f��
    ��C�
    �>�w���{�s�K`�ݼ���'n�("�b��3i�4� %��9Z�m��{��
    %��z��@��hJ��6���w�-��޳e-���E��g��~S�k�
    L�$�M�q�,�jtqD5�|%6۞�z����R�ꂞ+c�3#�7T
    #�Y�����`���X�J�˙�|ܽ��׳9T�%
    ��kT[Ѹ�}K"h���E�ե�-+�O���3�$Ehd�9\X���ٵ�IzT������V&�)���iԩ����임��̽�mqw���!�**�Eq��
    �}����AKB����=�T���yU��D+��
    Ӕ�/m/`��/��?��B��d��=z5�m��"�^j�z�~O�q,�'pC�ů�x�O4�J��5�����-��Hh`LXK������Ez�N��kB�'d1��E�AIه�Х71�>k����j�=wV����q�}�|p�*1e���znO�밝F����(���āg$
    ��>�\Q�����-G���0�1�'h�.P��;�ű�'�4�ʚ��Q\�~6͊��N
    ����d�u��s����d�@���f���>nd�?���3�M��@���S7'��� s��Y	 ��j��ed�k��F��>��U����|\誶�O�O4���J
    D�ڕÿM��[S��po���(�W)+�|��[�������\⍳�	��*�l1%'��;oy|eL5���>�ɛ��(I��
    E�	�Oz�)-_:5 �0]��l�fRHo#��������_�7E�=:��L�k�ӧy��R��K0��'���C}�\���h��CUBOeS�Q9���7�l��w�yS��֬��"�n����n���������SWDE��m�`�2������I�����/����`�Ζ�Y��,I.*�GO܀�c��H�7�>��`�7�Ժ�d˼aJ��WH|�O��]���I�U�B4Yn�ӹ%*�����qa��LF'/�cW��0�`��fi�oō�TE���J!���t$�����?��pK�X���5+q�}X�I��y�NN����2"(Ti��5܅�.�oZ���F���;)�(��W NqVڵ5��*g)��S�F���v�nM@k�Ud���"4+UG���C�v�,M�֍��`h��6L��X�'�>�EH?��ײb�'J<�����@�;�Fݡ��u�A��q���mi��г:���|@��cⲧ��6Xw�g[n�j+��h�"�|��C��$���xez6�؋n//�n�P�e��*3�?�
    w��Gr��u^�I�~Pڏ������HK��1�t����C�ˤ=^V�8�v2�P�G��\��<�쮏,��P �u�ćȧ%7��*o��!���\7�u�q�쎿�`o�>֒o���73�Bخ�9�|�UVP=a�?�2�������NM�_�y"�B�}��y�.;�n����Y�b����ґ/#`��<�A�Mo�(�6I-��ZU�y����v��)�M�|p�n��-��������߯�u*���j�Zc�����E���L��3ޙ 9���̯���մ/�n�:��ې���a+�:,��Z�����5���A����d�-�#�0���~�u����\���
    ���}ŝ��CS�bwFK!e�qÂ�[�QOl[����{Tm7©�X`�j_`V�zFg9jB��)�Q](��R� <J}K(�l�ر���Y�gV���cl����ض�pU�C����)^zΐ�3RX%XQ�.庼�����5�ls=�8�G�
    J	K��$b2YBRq����I3yt|
    �v��'�k���"�!�8�0������B���#k{� >W�J���O�>������-���H@��M|��g]3��(�U�@C���5������ǘ�7����ׇ5A���q֎O9d�~w�
    �L@4��V��s8���E>N���'2!�R��%�{a���s0i����9��#�����$(����<��>sn��1f.�Z
    ����+��k4��9��-�GV,%�p�-�l�<p/J��*�j�4�i������9�����1�G{{��G�/F�G�gn��#��3͏�Y������u��|U��9+���L|����D�r�k���d����d�hDAS�D �-�
    �3O?y�Nv����\U��5qwk���:�»+~�ɝ���)��P�u�y-�k_á��ї�)�ڕ�xU�qp��s3+7={�_*%X�|V[��~w�p�2/���a<i��]�G~4D��g��@�����@^1�edʗ����im��E`�b{e] �!��x��ؽ��	"�z���eI܃S���4�KΓ���pȓE��:��VGj��?4��I��z��L-/&��tWt�9�󾧔9�M��
    �:I*	:������8*G�
    ;,�����������{��k`]45�K�s2�;Rw�zZ0 ��{��MC�(/$�D������󅣊��U�3���/\ۓ׳Spx�A�ȶ��H̃\�g�n�����c�-F��\�n�4�P}3�S¾7/ubK l�3|���6W=�|;	��ĩ�%L=���lr������B'hR �R�(3����1h�����iXY�"��DЇڶvp^v���b��C�W�Z%��G�7�$3�y���u��֗���(����_) fF=�����o.��v��G����GE��,�E�w���ńZ��…6*
    �̹:��\iɅ�W�	y��ߖ�]��;%��?�����6�-����{���-�As�Ȍy�$�mK�s���؁��W�m�ƭ>�n"�詀x���#GS.�����
    �r���ө�#)j@�ʈ�����d���#��(��^���
    ̺��1^pI��]�t�F�v9m1	����0�.hJ�_�>%�s�P�'�g���YI�~���]��ַL�yt�l�u>��[g-�b�ҥ���v6��r��o��
    �W[��C���?������Z ����q��'�qA�
    �8P:Y�b�d���&Xz4&����fJ��>�OQ-�(�~����	4��hqa�'�yB�݌�J�������|xxC^�9weʫV�"��U�KЂJ2�*��-B7*�y	��Ļ�$����<SS#�$k������V���L���e!�R�h~���H
    1��U�Z˺&�14�q쓮�����l�[��ڗ��W?
    yo��m�L�&{���s^��|�oH�MǪ�����|�-��x���}*��A��n��F�)�t���͇F�`^��	����(x�H��vR?���Zғ0.��6@6��ڻ&`ru˿x��,�s�˫�A�5��9R��)_=b���q�U�'�lٗ��"�Y��ga1t�V+�Y�jSf�洪`~t,l@���<9����/��|¯S�Stک�5髞����#X*�&P��S����j�
    R��֟A�vV��)�m�B_�N�y�B<as
    �la���̝:[��E8M��(�FƊ�����5�O����p�€9ؿ�ڥ'���h��d��Eă�9�����>�
    �^F�A���ֳa��t�.�7Pb`W'���L�(MwO�?���\kݙ�����+nе'��@�MH�{�g?-�.4�q·1�>j���!3j.��f[9W"fQ�@$ N��=/?u�q}����żʗW�%�=�*,L�E�>7)���B��j(���QQp@]�.|���?�F>�*�J��|�8-����J�S�z%����	N���o�k�\������-m�F������a�"�,Ym��^�FL�>���-�����������p��E���{��>z�0lgjZ��Q�R6dLL�=�������d�����Q�$�W�0�k�����1�`	�'K��ӿ�t��v���Q
    ԭg�]�X�bN�[�D��dL���]��p4��J������'����;������[�ˋ�=���Cھ�Œd��T�S�Щ�
    ��D�<�a���:��o^�"�@~E�t	/&k��DAz�h/��N��W���lJ��>i9�-{FS(�c��V�}��a��0q�	�}���D	�U�m���q7L�jU�!�(/���0�Zr[���{X
    �����I�����^�~�Ess��󲴕�Y�D㏕/���т��&��f��/eM5xd��i9����5/V�����v1��1ޫ?���{��I�g��3���'�ޞ�hl�t�-�@��NM��ko���tBk�F0���j�vJ��P
    �����ŌiM��eQ����n4b��K~6_�X��CLyK�ҙFn(!�Uc��v��"[��]�����Y��_ت��z��g��o��VA�G{٧y8��V�k"�
    (K뵰z���A��p$wջ��;>8G+ꝳ�s����B�vo�����h#ڂ�����oy�m/1s�6���+
    }�vv��q�;�$��h��_ڒSL포�w�!��?Kɞ�<����a�����~���v�]�)@۠�ޞ���F�P�$��7qF���ܡB;#k��>�q"LJ-�9�����D�3�T�t�������Q�?��:�M��6�Iڋ*�
    �=#Y֏�i%���q�WN"���Jٰ���~˫V	2-5��
    �:j}fWR�N	�8�a��nH�bB��ct��1*��f,���n4��E�|F��xF{����]��1�����?8�d
    V+�a�KZ�0�q���u�xJ�,��xk}�(��œ�.�Q{E�۵B��+�a�M+'Ǒ�^�>�%pSb�U~8W�m@n����gi�D�ʲ&<s��'�͝0�-�N�$D����v�A�	�M�I������'C��^�U�9��F
    �Wc��t��m�;�?���Ľz�*N�x0}���\'{��.Q+�w�����t�rQ��ҶA��W8{����x*�U��x�'���,���/WoZWQ����F�+릇年-�v�B ���y쁞;���S>؛h��x�g�k+=������S�1��`��	a|���PYL ƣm����t5��[$O��*���Y^��ڢ\��	����I9}�!~������v~�I-J��ʴ����U�?��bO����#�Ʀ�[Y��r���FK�@��Ɉ���Æ�n��,O�a���2����xSt�%��;����a�'dm�L5ݝ�v�s��+��q�C���D�`���m�K��OY$S��R��	�ˢ؎�]�Vd��%Q,nP"5X�'��lXޜ�kP�(��8О#����w6o�4�l��u��H�j����Ȳm�������ڙ�]&>%�1�b
    ���.z*]D��jŮ?��ɘ`�!�낈Eq��T���_ �f�Ӡ�B�Q
    �H��12Ϧg��	ZHooJ��V ����8�N�.L$ؾ�?c�yZ��d�G���ԅaos
    Y �<�us;i�d�f�9�	�D���~-��Q#\��*�Խ��hVB?�X�bz�����kl��-J��&˟��cgG������D|�C:���E:uhQoܪ��8{l%2�{�)�L/T"iӵ.���]�2חĹ
    �Fkn�<)u�����u\�;��HCOf��6`%��.7qB���T���Rԕa�TXԋ.I$�+�n,�R\\_��$WHo�����ūd�j��3)Y����Y�`
    3*��a̚F�����Ļr�@�7�M��֊X��$\�g]���uK�ߏ�S�������3����M�2�E��T�S��+%���{��|V��­J�
    ����'5_�����YM��b!{3��;�S�U�������`�O�X�w� �!s	3���ǩ�����_|�qEՁ�})�
    ި|���J�w	ZBm�כod�ж��f��$0`�� u����;��
    �H	�ԕ$�z]:���X��:��3�Z���ݛh�8�c��Us@����V�LQ �Z�Z�{Q����*sym�������)�\Ki�/b³�@S��f탠��rΎ_�;\� FF��}���1]=�UiG�S����|Mz�md�^���-��ͤX�5��\ε�m
    ����'~�U�x��n���'�E@bR��J�0���V��˜�>�h�q�a�h�������B&(������/@��
    0<�-͟8z�������ʎ��H�?oc4�p�_��]�:h�����f�\<e���8WIg�x�I�S��{�R��4l���`�ZbA��*��<�IU��y�����2ˆ|�3�;A,"G�D_����O�>��`�h�Z�:��x%9���SkB<��#�*DR14u�s�����YiB'^f<�Y%�<�N+?p�ݧ�����%ƒD��!����1[����HPM�W�0�!(lHzaX�d��/r�Uü�,��ˉ�m�k�)8<�u��'pn�Q$W����me5�#v����d+�KS`y�s$$�	n���2 �|[��H�дݧf�ә�pN�#�$�|���=^E(�PIgU��i8��3�jg*�B��7f��_�b��=/@�(!
    �'Į��N�t,�k����v;e�RJܤ|�iY�D���2�(n�s4;Ҵ���i����jna��!ys��wte�e��Ŵ�w	i��������ͧ���M��$�Z��I�5�\�A�I[58S�o@X��\8�ĉ��F|覫e�:]H$�F�;��Q�70Q�����q��M�w'��yF�� B3�Lg����|x�͚%<35��"C��*�O��(�ϼ�]���z��+9���i?�xp��$-��&�M�3�\�ራ�����|@�UMЪ��!����W�u_?�,u�id���f�o�V�wD�"K��S��������b���AlbUe�W%�d��,p�D(D�x�"��TKmӊ["=SvN�&D�=���E�7w�#Dd�;z^^�o�в8U�Q3�S*t��f絅_�r�ء�b�
    h\�Դi�Kĥ�]��>5�j�_��5�ԏ?�1�������k����K �:�հ���������� ��֪��>íX:�+��yp�~�˅�3F��=���?�O��pc:ɴ� ����K�)3>��}s39�t�%���4��-�D��A�3T�#Zz�c��u��D-U��v�y������N�wK��n�����=�r�G��c�!��^f�j��=���HΘ�Es����+A�wۆܡ߈�oK�MK{V7��M�W�3x����15�,�����ɖ��P�[<���B�U��㉒� M�	˷+%���f!�]��~wJ:G���?��ŀ����;�q�B/
    JV���C����O���=
    [����<6u��J��%�%�K�5e^ϒ�,w��-�n��3���~�پ������G�sm�M��9��h߰g��Gđ�W��<�Yn�{��{�������g�[MC
    ADړ*��u��6.n�`�U�p5j{�E0�br7k��,ј�(>��&Ӿ�;���d�d�X���in��d�6i�mP˪�Bm���v'��e�ؾ���a�7��f���n]z��2ICQ;َ`�k�=+�b#�t�N±����+΢=�������S����?����>u��f�9�p���Q�א��黅=����/`�3�c�3�^��U�T�!��h��U�Ĝ���m���E�f�Q�uU�����"��;�
    <J(_ˑ7�1����%�*iR����1z+����Q햗D�!q�xj�R��h6��K�y��ƥ���B��2-	o�\
    �Z��T�gF+w��m����_�� P����M����rz
    ��:f}�y�omՄw.:�1t�lť5�j��s�wБUĽα����ԁhm=z��Z�x�"*��G$�T��d)L,�+`j+�^�
    no*�"��S�$�R̪h�_�D��˞ ��怒�,-�[�_�f�D����d�=ӄ���������Ȕ U��r�ʩ�,�j�F�>tUg"�F��ױ�]�K=�Tԕ�� xW[�vb O�АN�����Y.����p�e��X{r�������C�VأAP�܍��3c���1�Ћ7��׿�e@�{X�SU]����h����~�$��B^T1Ҷ;�/Û�N��Y�@�Vd���P��"��Y�4���u���d��i]"�x�W@�-�c}����C�ԛ�ٚ�0��)�0@X���d��)wT��^�����.|Aq�Gѯ�4�Z��UG�8TW��.��Q��Vɦ28�7��i��,�U���E�..l�?�Ӑ����/l;�
    /��հƀ�6�,C��"zt=9���rl\�s�W>�)����ļ7��#q{aR�_�(?��J��)��m.���&`L*�v\}�����^�pc)��p�A9���{Tŗ�]��e>�E$k�>G[,#����X�{nXέ�c��*wp`��(u�?E��Ro:��?�r<\?%S��1��^ %�u�]�ϟ�06�e��L�H���*(���I�6��&�gBYVD'ա'k
    X��g:��C]w�]jR��M!<����6I�� �/I�zX�s("�&�}i��ʲ�5��b��8�{�A�K�G�����Z7��(�9�察�`�.�#�hFEZ�24@�C�!̞�7؟ ��[�oYr4���e1�G�{,�`�0��wH%@qB�`�ڍ�(В��Z�\����]yK����Bpց�f.yE�|�����POl��oK)!�)y��K�2�@�wQ�(�7v�}ǜ��m]-�.O&ƥ!3�2J↵�9��/���p��1o!�����-SFdq1�����͛6��~H���0ZwR]Tȕk�׮M�ј��x�k�ԨeF������A��٦�{��|%ž�o��#�,�?!'�6S�u1r���q��0��|�l4�WĨ���r@�SVG����w��}���۰��;ir�="�Lb
    0;k��%ǤF���|lNR����w4���/�A��t�i��O��@�Go,Hv;�͡?ު���c���3F��������?�@guW��5����M�5�1����Z[&ޢ
    b�W�4�X�Ŋ���ih~�	���%��_����XjR/��Ӣh��Χ(�]�~��uL/���2�s�) �R��6E���c���Y
    9f}�3�J������9�I�����7O���:�ރ:
    �B��&_ШG��ػ�ۅt�Y��T5��#���zdft�&yF���
    ,5�`h����X�ƁG��^}D/��D�Fv���~\�&@Ӕ���7��N�`�-�kvXX?�z\�lvIC�w�l�w=��
    �5J�P�YeC�Ӹ���u5�-܇���f4%H�j��b�iq�8��w��OsY
    B4R�����~O;��T
    ��[;��қ[���q��g�直�k�����nB7�f��C����;8K��޵f�z���� �lwv�A�_n�
    �¯���U�N*�IV)cW�dfI�nl���M�
    t���"P��*DܘJ$_߬���⚺Q��Ǻ����Q���ˬ!��cs��V���
    [S"g�0�N��k�t�W��J�9��M�m�M�J�9��C�wB����W6�%؈p�$��q����Wk�� b��̧R��r3�	F�����Z4BS��^̉�1��>�e������R]�9���6_���OvF�R�U9K�	�t;�`R�j��p�"٘�	!�5�G��5s�>ϛ����e����Ҝ	���^�$��k�Q-a<#�a�N��G]�]��$��@!3�ؼf�w{��J�-x��fQޖ\�i��SE��%�#��tY8�O܌k+�� 	�/2#�*3]��NaƖ�#zri�f`�,��K\�(�]�OoR�8,��ŨI���/����r���&*�R�C��>�c�3Szw����"�ohH
    �k��������FÇ��efɾ�z��¿˩�yv�B�}1И�b[��zym�r.b��vh���+C����6��x�$d�����/�!�
    ����X�zYA��\�&� �
    §�&�_{<6���߬V����"�3�ןz=8�JHkb�����%{%��lU�v���F,�E��dᑳy��n��`��k�e���qT��/MȚR:m.5b�3����*x�rm�ɟ��華1�	���s!��6�0K�ʾ{9��X0�<�h��y��7 Y��>�{���c�)&��f���+������
    <?xml version="1.0" encoding="utf-8"?>
    <Job>
    	<Version>1.3</Version>
    	<ComputeVersion>12.0</ComputeVersion>
    	<JobName>job_20200504T184959_1_20191129_33_drone_MX8_B16R1P1_Tile_1</JobName>
    	<TaskGraph>
    		<JobInfo>
    			<Descr/>
    			<ProjectPath>//172.16.101.71/d/PSV/ContextCapture/20191129_38_drone_MX8\20191129_33_drone_MX8.ccm</ProjectPath>
    			<ItemPath>Block_16\Reconstruction_1\Production_1\Tile_1</ItemPath>
    		</JobInfo>
    		<RunInfo>
    			<SubmitHostName>OT7_104_06</SubmitHostName>
    			<SubmitUser>anikitina</SubmitUser>
    			<SubmitTime>20200504T184959</SubmitTime>
    			<Run>
    				<RunHostName>ot7_401_11</RunHostName>
    				<RunUserName>eklestov</RunUserName>
    				<StartTime>20200504T185005</StartTime>
    				<EndTime>20200504T185014</EndTime>
    			</Run>
    		</RunInfo>
    		<JobFeedback>
    			<Status>32</Status>
    			<Percent>1</Percent>
    			<Msg>Matching photos pairwise...</Msg>
    			<PT/>
    			<LastError/>
    			<Tasks/>
    			<TimeIntervals>
    				<TimeInterval>
    				</TimeInterval>
    			</TimeIntervals>
    		</JobFeedback>
    		<Task>
    			<Type>4</Type>
    			<Workload>100</Workload>
    			<Run>
    			</Run>
    			<Id>0</Id>
    			<Status>307</Status>
    			<RetVal>-1073741819</RetVal>
    			<DefinitionJson>false</DefinitionJson>
    		</Task>
    	</TaskGraph>
    </Job>
