Hi
I’m new to this forum, so if my question is not in the right place, please bear with me.
After doing the 3D model (both local or in cloud) I would like to have the opportunity to study the original photos for a specific point. Is this possible?
Thanks.
Hi Jesper,
Yes, this is possible if working in Update 15:
1) click on the 3D view
2) in the bottom right corner click the little icon and switch on photo panel
3) then in the top right photo navigation.
If working in Update 14 then use the following:
https://www.youtube.com/watch?v=GHRmamfnOUU
As you will see once you have photo navigation open you can click on either the splat or the AT and it will highlight in the corresponding data.
Hope the above helps!
@Jed,
Your answer is about finding photos from the AT. Is there also a way to link back to the photos depending on an area of interest in the Reconstruction (3D model)? I think that was the question and something that I would be interested to know, as well. Thanks.
Hi Russell,
Apologies I misread the question and it does look like it's after the reconstruction, in that case the only way I'm afraid you can do this at the moment is through other products such as ContextCapture Editor which will allow you to overlay the AT with the mesh, this feature can be seen in the avi below.
https://youtu.be/xNrIF8rPvPM?t=107
Thanks, Jed. I will take a look.
