Hi everyone, I'm very new to the Context Capture software. I am using this for work to generate 3-D mapping and images. I have a problem with one of our outputs...it seems like it is unable to display the 3-D image. What am i doing wrong? I have provided some pictures for you here: Any form of help would be greatly appreciated ! Thanks !
Most likely some of your data is at zero coordinates(null island) it tries to show all in one view so only two small points are visible.
Ohh i see ! Hmm how do i fix this problem ? Is there any way i can get the 3-D view to show ?
I have asked previously for change to ignore zero coordinates(Enhancement Request 358427)
You have older version of CC so it is not possible to not show photo positions. In CC U15 it has new 3D view with more options.
So you have to delete those 137 photos or clear metadata for them so they do not show in 3D view. Or if you will create reconstruction then opening in external viewer it will show correctly.
Ohh i see ! Thank you so much for that, i'm really new at this and i'm still learning how to make sense of all the information in the software. One newbie question: How do i clear the metadata from the photos ? I'll try to do that and see if it will generate properly.
Select photos in Photos tab and right click with mouse button.
