I am a new MicroStation user (Version 10.13.01.01)
When I open a drawing, my screen looks like the image. Descartes is not loaded until I click on the Load (D) button. I would like for Descartes to load all the way when the file opens. How can I make that happen?
I am loading this on the MicroStation Forum (because I am almost finished). It might be better on the Descartes forum.
According to my observation, you could Add DCARTES from Configuration Variables > Design Applications. You will observe an Alert dialog pops up when you run MS next time. All you have to do is turn on "Do not show this again" and click "Proceed".
Hope this helps,
Hyung
Answer Verified By: Koog
Just be aware that Descartes requires its own license. Even though you can install it with MicroStation, it is a separate license.
Rod WingSenior Systems Analyst
Although Hyung Kim answered my question, I would like to know why the problem (half loaded app) existed to begin with. I would also like to know how to do the opposite and have Descartes not load when opening a file. I assume I could take DCARTES back out of Design Applications, but I would probably be back where I started with the D symbol showing.
