Hi all,
There is a lot of discussion about Task Navigation in MicroStation, but I have the same problem in Descartes Update 6. I am able to add a new Configuration variable, and yes, it was shown in the ucf. But I never show up the possibility of 'Task Navigation" in the preference tab.
It is annoying that this option does not work, anyone has an idea?
regards, Aart
I believe you are referring to the MS_TASKNAVIGATION_CONFIGURATION variable.
The variable was only supported in earlier versions of MicroStation CONNECT and has since been deprecated with the addition of the V8i Task Theme in Update 13.
As far as support for the old Task Dialog in Descartes CONNECT there is currently no plans to reintroduce the task dialog as the Ribbon is meant to act as the primary interface in CONNECT.
I would recommend filing a service request and requesting an enhancement to request its inclusion in a future update.
