contect capture merging blocks not highlighted??
I have 3 different sets of photos (1. aerial nadir at 200', 2. aerial oblique at 150', 3. iphone ground photos). I've AT'd all three sets in separate blocks, in the nadir set I established tie points, imported them into the other two blocks as CP's, the two blocks with the CP's will allow me to merge them, but the merge is greyed out when I try to merge the original tie point set (nadir)?? Should I have turned those to CP's at some point, no directions on any forums stated to do that?
