Hi Im getting this error when trying to import a touched up tile geometry. I followed these steps to touch up the dgn file that I exported from CC Master (using CC editor)
Im using CC Master Update 15 - version 10.15.0.21 and CC Editor Update 3 - version 10.03.00.23
The unprocessed and processed geometry files (9 and 12) are shown because I re imported the original tiles as I told CC to look at the directory with all my tiles in.
I dont understand why its failing...
So...me either. Did you solve?
I face the same problem like you, did you find a way to fix it?
For now my only way is to retouch with obj and not with dgn. But I cannot understand why I have that problem and obviously the solution....
