I'm getting the following error when sharing one of my 3Sm productions from BCC Update 15 (10.15. ) to an associated project on ProjectWise ContextShare. I have successfully shared the other 3Sm file in the same CC master file, strange why one worked fine and the other not. Is there a file size limit? The error code is 22.
When I open ContextShare I see a file there but only 1kb whereas my other 3Sm file uploaded fine and was 1.7gb
I am having this same issue. Was there any solutions to it?
I havent had any reply yet. I am working on another dataset now and the 3SM files are publishing fine but the orientations and photos keep failing on upload from CC...
