Hello,I want to create 3d mesh of a building. The problem is that every time i try to run a Production i got an error message or the Production is stuck at some point. I see that none of PC components is used (RAM, CPU, GPU) and even if i try to let it process it wont go further. I tried to let it process a project for 9 hours and it was still stuck. I have 220 photos (aerial and terrestrial) of a building. I import them to ContextCapture, I enter the coordintes of control points (WGS 84) and then indicate them on photos. I also use Tie Points to make a connection between aerial and terrestrial photos. Then i use Submit aerotriangulation button. After that i import point cloud to the project (in .ptx format) and when i go to 3d view tab i can see that aerotriangulation of photos and point cloud are correctly aligned and they are in the same position. Then i start Production (I want to create .obj file to correct few things later or at least .3sm) and during that process i always have an error "Failed: Operation failed". It is my first time using such software and i am unsure if i do everything correctly. Can you tell me what the problem might be? I attached log file for technicala support.With regards.
Failed Operation failed.zip
Hi Rafel,
All of the data you need to share can be uploaded here:
https://communities.bentley.com/p/secure_file_upload
I uploaded temp files. The .zip file is named "temp_files_Rafal_Jez.zip"
Hello Rafal,
I looked at your temp files. You seem to have a coordinate system issue: the data you are trying to reconstruct is in a cartesian space with very large coordinates. This is what is causing the issue in the processing. Even if the processing was solved, the model you will obtain won't have a correct geometry - I invite you to open geometry.a3d file with the CCViewer to understand the issue.
In order to solve your problem, you need to reimport your pointcloud files in the correct Spatial Reference System. Same goes for the images that you are importing. Let me know if that works for you.
- Cyril
I know that point cloud is in WGS84 coordinate system but everytime i try to import it this way i got an error message:
Can you give me details about this pointcloud? Is it a LAS, an E57? Do you specify the scanner location yourself?
