Hello there,
I'm trying to save a screenshot from the contextcapture Acute 3D viewer (a 3mx file). All gos well, it gets me to the stage of choosing a folder to save in, and all looks normal. But after pressing "save", there's nothing in the folder.
Any idea what's the problem?
Eyal
Hello Eyal,
I tried to replicate your issue with our viewer : open a 3MX file, then File > Save Screenshot..., then Save. The image is correctly saved where I wanted it to be. Can you check you are using the latest viewer? (Go to Help > About..., version should be 10.16.0.75)
- Cyril
If you change the location being saved to does it make a difference?
may be permissions issue to location.
