Orthophoto job failed
Hi expert,
I have made an orthophoto, but often my output will fail because one tile reference has failed. That failed tiles is completed generate in 3MX model.
     12-Hartamas-Matrade-IKIM_ - Tile_-040_-003.zip
Parents Reply Children
  • Check if there is a views.bin file in directory D:/2020-KVMRT3/Project files\Block_46/Reconstruction_2\Tile_-048_+001
    • If there is none, clone the reconstruction. If you have already run some tiles and don’t want to lose them, you can manually copy the 3 files from the new tile directory (D:/2020-KVMRT3/Project files\Block_46/Reconstruction_NEW_CLONE_RECONS_NUMBER\Tile_-048_+001) to the previous one (D:/2020-KVMRT3/Project files\Block_46/Reconstruction_2\Tile_-048_+001) and re-run reconstruction on this tile Otherwise you can simply run a production with the new clone reconstruction.
    • If there is one, please send it to us so that we check if the file has been corrupted?
    • Another possibility would be that the disk where the temp directory is hosted is full. Please check the available disk space.
