Hy everybody
I am now working on a project to build a 3D point cloud from images using ContexCapture. And I need to know the projection relationship between each image and the 3D model. So, does anyone know how to find the translation and rotation matrices?
Thank's in advance
Joey
Hi Joey
You can export the AT block to XML (Right click on the block > Export > Export Block...). The resulting XML file contains rotation+translation matrices. You can find more information about the XML format here.
- Cyril
Answer Verified By: Zhongming Xiang
Thank you so much. It works!!!
Thanks Cyril, I have been looking for this information for a long time. jiofi
