Tile_+005_+002.rar
Hi, we have a project running the reconstruction processing. But only 20% tasks are sucessful to complete. The other processes have the same error "Failed during 3D mesh export". One log of a failed task is uploaded. Please help me! Thank you very much!
Hi kh,
You are using an old version of ContextCapture (Update 10 was released in 2018). We recommend you upgrade to ContextCapture Update 16.
Looking at the logs, it seems your Z: disk is running out of space, since we failed to copy a file to a folder in this disk.
- Cyril
Thank you for your reply. We use a shared storage with a lot of space left. We also suspect that the storage is not accessible. But the files in cache and project directory can be accessed through explorer.exe in this shared storage. We checked the original images using checking image tool and found no errors. How can we find out the real cause of this problem?
We have another problem and export the error log attached. Please help me to check it. Thank you very much. Production_1 - Tile_+005_+004.zip
If you can't upgrade, try deactivating Vulkan, and delete cache folder in your block in the project files.
We will upgrade the newest version. Thank you very much!
Hi, we change a newer version. There are also some errors. Can you help me find out the problem? The log is attached1028_01_59 - Tile_+029_+019.zip.
