AT treatment with 2 photogroups (ground and aerial)
this message follows the problem of AT processing with integration of facade photos.
I have integrated Tie Points and control points common to both groups of photos.
I have selected the "tie points" and "control points" adjustments
I applied "high" in the Keypoints density config, as well as an alternate engine in the preset.
Analyzing the result of the aerotriangulation, the 695 photos of the facades were rejected. When I go to the 3D view tab, I noticed that the altimetry of the matadata of the pictures was shifted: since the pictures were taken in 2 steps, it seems that the altimetries between the 2 groups of pictures are shifted by a constant (that I don't know). Knowing this, I took care not to take into account the metadata in the aerotriangulation configurations.
I then carried out a second aerotriangulation by which I was able to parameterize the menu "components" which indicates to be able to use all the photos which did not follow during the first aerotriangulation. At the end of the TA process, I have again the same problem, my photos of the facades are rejected.
What other options are available to me?
Thanking you in advance
