I have produced a reality mesh (3SM) for a 10.5 mile roadway. I would like to produce a raster image for my designers to place linework over. I would like to have sme resolution as the 3SM. Becuase of the great legnth of the project I am havin trouble balancing the DPI, Scale, Sheet size, etc...Does anyone have any guidance on this legnth of project?
How will this project captured?
You were not specific enough. So you are using Descartes/CC Editor Merge tool to produce Raster images? Keep in mind that it doesn't support BigTIFF format so you have to keep resolution for each raster Tile rather low. Basically there is no reason to set resolution lower than Reality mesh average resolution.
sorry, misunderstood question, I create rasters by merge function in descartes connect, is there another way to create raster to increase resolution?
You need export in smaller tiles. Not sure but there should be a Tile Terrain or similar option to do that.
You can't increase resolution beyond the reality mesh as there is no need for that.
