What size do April Tags need to be?
I created a project.  I went to Tools and saw that April tags need to be at least 35x35 pixels.  If I am flying a job with a Phantom 4 RTK at an altitude of 71m AGL that gives me a GSD if 1.95 cm/px  If we calculate that out to 35px by 35px that gives us a target size of at LEAST 28"x28".  I use the 71m AGL so that according to Bentley I should be getting an accuracy of +/- 0.20' vertical for my meshes.  (That is 3x the GSD.)  We had planned on printing out about a dozen or so of these to have as permanent targets that we could take from site to site and have quick control points.
Having to print these onto a piece of media that is about 30"x30" makes this process a LOT less desirable.  Is there anything we can do to bring that size down some or is 35x35px the minimum?
  • Tags do not need to be visible in meshes so 3x the GSD is not needed. Tags are recognized in aerotriangulation step using full photo resolution(not sure what happens with downsampling).
  • Good morning and thanks Oto.  Not sure where I miscommunicated.  I do not need to see the tags in the meshes.  I just meant that I need the meshes to be accurate to +/-0.20' so I have to fly at a height with that in mind.
  • Theoretically one tag pixel should be at least 1 pixel in photo so 35 pixels are to be on safe side. You could try to use smaller tags but honestly it is not worth the effort as they may not be readable or may be blurred or contrast is too low. If it will not be readable then you will have to mark them manually. What you could do is print/order print the targets on ISO A0/ANSI E sized paper which would be biodegradable and leave in place. Another way of course is use zoom-by-foot so after automatic mission zoom to each point by taking some photos in lower altitude above.
    But for P4 RTK it would be enough to just mark two user tie points for constraining the model and use RTK georeferencing. Also reusing good calibration will help to get most of P4 RTK.
Reply
