AT: Issue with the acquisition!!!!
"Houston, we have a problem"
I think the new update broke ContextCapture, because with the old update I had oriented 68 images without any problem, and now with the new update and using the same settings and the same images the software only orients 6 images correctly. I think this is a big problem that you will have to solve as soon as possible or at least tell me how I can downgrade the software version.
  • Hi,
    Update17 AT engine is sensitive to improper pose metadata even when the position/rotation policies are set to "compute": it is likely that some rotation metadata are not correctly imported.
    There are two workarounds that you could try:
    - clear the rotation metadata: right click on the photogroup -> clear pose metadata -> clear rotation only
    - use the preset file bundled with the installation: "Do not use pose metadata for SfM.cfg"
    Nico
Reply
  • Hi,
    Nico
