Hi everyone, Im trying to realize an AT of a block with 910 but I'm getting an error when matching key points, the proccess stalls at 75% and the engine's message is: [2021-Mar-01 10:27:24] Error: task failed (returned : -1073741819). Ther is happening with every block I try to triangulate.
This are my AT settings:
A. Positioning/georeferencing:- Adjustment constraints: control points- Final rigid registration: noneB. Main settings:- Key point density: Normal- Tags or QR Codes extraction: Disabled- Pair selection mode: Exhaustive- Component construction mode: MultiPass- Blockwise color equalization: Enabled- Splats: EnabledC. Estimation policies:- Tie points: Compute- Position: Compute- Rotation: Compute- Photogroup estimation mode: MultiPass- Focal length: Adjust- Principal point: Adjust- Radial distortion: Adjust- Tangential distortion: Adjust- Aspect ratio: Keep- Skew: Keep- Estimation groups: PerPhotogroup
I also have 40 GCP and 14 user tie points. I've created a model before with the same block but I had an error with GCp heights so i've to run all the proccess again.
I hope you can help me
FINAL - 1 - AT.zip
Hi Javier,
You are using the pair selection mode set on "Exhaustive". This setting can only be used with a dataset of 100 images or less. Your dataset contains 581 photos which is too much and it will cause the AT to fail. Use "Default" settings instead.
Also, have you tried to run AT with Default settings first?
Bruneau
Hi Bruneau,
I've tryied with default settings and the AT stills failing. I'm running a AT from a AT, just correcting heighs of GCP, could it be the problem? now the procces is not failing at "Matching tie points", now fails at "pass one"...
Send us the AT log file it may indicate us what is causing this issue.
The AT log file is in the first post.
4375.FINAL - 1 - AT.zip
The Pair selection mode cannot be set on "Exhaustive" because your dataset contains more than 100 images, it must be set on "Default" and try another AT.
Okay. I'm running a new AT with default settings and got error:
A. Positioning/georeferencing:- Adjustment constraints: control points- Final rigid registration: noneB. Main settings:- Key point density: Normal- Tags or QR Codes extraction: Disabled- Pair selection mode: Default- Component construction mode: OnePass- Blockwise color equalization: Enabled- Splats: EnabledC. Estimation policies:- Tie points: Compute- Position: Compute- Rotation: Compute- Photogroup estimation mode: MultiPass- Focal length: Adjust- Principal point: Adjust- Radial distortion: Adjust- Tangential distortion: Adjust- Aspect ratio: Keep- Skew: Keep- Estimation groups: PerPhotogroup
FINAL - AT.zip
The log file as not given any clue to what happened unfortunately. You can try to clone your block AT and submit a new calculation.
