Hi everyone, Im trying to realize an AT of a block with 910 but I'm getting an error when matching key points, the proccess stalls at 75% and the engine's message is: [2021-Mar-01 10:27:24] Error: task failed (returned : -1073741819). Ther is happening with every block I try to triangulate.
This are my AT settings:
A. Positioning/georeferencing:- Adjustment constraints: control points- Final rigid registration: noneB. Main settings:- Key point density: Normal- Tags or QR Codes extraction: Disabled- Pair selection mode: Exhaustive- Component construction mode: MultiPass- Blockwise color equalization: Enabled- Splats: EnabledC. Estimation policies:- Tie points: Compute- Position: Compute- Rotation: Compute- Photogroup estimation mode: MultiPass- Focal length: Adjust- Principal point: Adjust- Radial distortion: Adjust- Tangential distortion: Adjust- Aspect ratio: Keep- Skew: Keep- Estimation groups: PerPhotogroup
I also have 40 GCP and 14 user tie points. I've created a model before with the same block but I had an error with GCp heights so i've to run all the proccess again.
I hope you can help me
FINAL - 1 - AT.zip
Okay. I'm running a new AT with default settings and got error:
A. Positioning/georeferencing:- Adjustment constraints: control points- Final rigid registration: noneB. Main settings:- Key point density: Normal- Tags or QR Codes extraction: Disabled- Pair selection mode: Default- Component construction mode: OnePass- Blockwise color equalization: Enabled- Splats: EnabledC. Estimation policies:- Tie points: Compute- Position: Compute- Rotation: Compute- Photogroup estimation mode: MultiPass- Focal length: Adjust- Principal point: Adjust- Radial distortion: Adjust- Tangential distortion: Adjust- Aspect ratio: Keep- Skew: Keep- Estimation groups: PerPhotogroup
FINAL - AT.zip
The log file as not given any clue to what happened unfortunately. You can try to clone your block AT and submit a new calculation.
