Hello, I have an problem with loading photos from *.xls/*.xlsx. Mainly I have problem with mask, because according to help section:
Masks are associated to input photographs through their file name:
Associate a mask to one photo: for a photo named "fileName.ext", the mask file must be named "fileName_mask.tif" and placed in the same directory as the corresponding photo.Example: for a photograph "IMG0002564.jpg", the corresponding mask should be "IMG0002564_mask.tif
I have the same mask name as orginal photo name with added "_mask" in directory with photos but mask isn't loading possibility. Is there any possibility to load photos form *.xls/*.xlsx with auto-loading all mask to photos what are created?
@ContextCapture developers: I'm having this same issue. I've been creating masks, but they don't seem to be importing into the ContextCapture software. They aren't appearing in the photograph "input area." Any help would be greatly appreciated.
mask need to be same resolution and in TIFF format. Ideally BW but RGB also work also compression seems to work.
