Can someone help me with how to import 2D CAD Drawings in pointools. I tried several times importing from AutoCAD R14 to 2013 Version but nothing happened, i.e. Nothing Import, No Processing at all.
Thanks in Advance
Hi Arvind,
Please try saving to AutoCAD 2012 DWG or DXF format and then attaching the file in Bentley Pointools.
You might want to check the point tools documentation as to which versions of DWG files can be used.
Hi Felix,
Thank you for your suggestion.
Its working when we export a Layout as a drawings from main export menu in AutoCad 2012.
Thanks for your time and solving my problem.
Answer Verified By: Arvind sharma
