river divides my project
hello, I will be flying a site where a 1000 foot wide large river splits the site in half, is there a work flow I can use to be able to get this river to show in the aerial ortho image I am going to produce? Im also worried about the two sides of the river not being able to connect becuase of the wide river gap
  • To connect both sides you need to try load delivered custom settings.
    Keep all components for adjustment: If you set the poses policy to “keep” or “adjust within tolerance” this preset allows you to keep all the photos, even if they actually are several components that are not connected through tiepoints. A typical case is two sides of a river.
    Alternative is to do each side seperately and then merge blocks.
Reply
