I hope someone has an idea of what is causing my error. Every time I submit for aerotriagulation I receive this error.
This is a fresh install of all the ContextCapture software.
Any help would be appreciated.
Thank You!
We think that this may be a side effect on another application that has ben installed on your system. Please see the instructions in the link below to try and fix it:
Use the System File Checker tool to repair missing or corrupted system files (microsoft.com)
This didn't help. Still the same issue. I have reinstalled and tried on two different PCs. The only one it works on is my laptop, which does not have the power for this type of work.
Our development team are investigating this issue. So far as I've stated previously we believe that it is a side effect of another application being installed on your system. We need to be able to narrow down what this is to find a resolution. We will keep you informed.
