I would like to know if Bentley recommend any particular GPU for AWS and its installation procedure. Since we are creating a project where we need to add the production to the Aws.
if there is any, what will be the cost of it. I would appreciate if I will get the response at the earliest.
Thank you!
Best Regards
Asiya Zahir
The GPUs will require openGL , most cloud machines do not provide the high end "gaming" type GPU that provide best speed.
Attached is a document for hardware suggestions, while it is not up to date most of the hardware has released newer versions of the same series.. i.e.Nvidia 1080 > 1080ti > 2080 > RTX 2080 ect
hardware_suggestions_2017
Michael Barkasi
Application Engineer
Reality Modeling
