Hello All,
Has anyone else been experiencing absolutely abysmal performance of Connect with point clouds recently? Even really small clouds like 52mb are crashing Connect.
apart from crashing...
Takes a really long time to be able to pick off a point.
Things get even slower when a clip volume is being used.
Better performance of clouds when they are a local reference but still $hitty performance.
Tried with different databases from different machines, phase and pulse no perceivable change.
Compressing sometimes helps. Not really though.
Side note: Can we get a fix for the Reality Model / Level Manager problem!?!?
Win 10 64b
32gb ram
Connect - Update 16
I'll answer my own stuff again. "Go back to v8i ss10". Solid copy. Everything works.
Answer Verified By: Jeff Berleth
I have the same experience with Update 16 as Jeff describes. I compared the performance with Update 15. Update 15 is significantly faster. There must be a bug in Update 16.In Update 16, before rotating the view, we must turn off the point cloud layer and turn it on again after rotating the view.
