I was used this manual to create 3mx for web https://docs.bentley.com/LiveContent/web/ContextCapture%20Help-v10/en/GUID-FEED2A71-66F5-4042-95E8-0DA2D827E21D.html
I got 3mx for web, but not clear what next step?
I need share this model to other customers, whom want to see it without any desktop software.
I find such exmaple:
http://realitymodels.northeurope.cloudapp.azure.com/rm/Krustpils_pils_3dtiles/App_CCWebViewer2/index.html
Is this somehow related to the ContextCapture web viwer?
Please see the latest user manual for ContextCapture Update 18 from the lin below:
https://docs.bentley.com/LiveContent/web/ContextCapture_User_Guide_EN_PDF-v18/en/ContextCapture%20User%20Guide%20EN.pdf
Please note the following:
P183-184 : for the ContextCapture webViewer
(p185 is for CC web viewer 2.0, which is to be removed from the doc as it is no longer relevant).
P 229 : producing 3MX ready for web publishing.
If you have the 3mx file all you need is a web server (static) or a blob repository to publish the information.
Deploy on the internet (bentley.com)
I used this tutorial and worked really good
Host a static website in Azure Storage | Microsoft Docs
there is no simple online viewer where I can upload a model and share access, am I right?
If you are not a large scale business then no. You will need to have you own server and storage.
You could create a wordpress website and add a subdomain in the publichtml, then upload the scene folder to the server using filezilla or something. The problem is that anyone can download the whole scene and some shared hosts often block such access. I had this solution a while ago, but now I prefer Azure, it's really cheap.
