I would like to cut a long section through a reality model along a curved path, so that I can produce a vertical orthophoto. I am aware that it is possible to use the section tool and the "vertical along path" option to cut cross sections along a path, but is it possible to cut a section *along* the path, rather than across it?
You can use the connect release products that include the "workflow" > "Reality Modeling" (i.e ContextCapture Editor, ORD, Descartes ect)
then select the deliver tab > Merge command from the ribbon.. this will allow for vertical or angle orthomosiacs such as building face, or face of dam ect, but it will NOT cut a section along a path
you could try to mask the reality model and rotate the view the use the mask command, but not sure it would give the results you are looking for
Michael Barkasi
Application Engineer
Reality Modeling
