We are using CC Center and running into an issue on the Engine computers. CC Engine seems to be writing temp files on the local c drive. But the main storage drive on the computers is the d drive. The Engines quickly fill the c drive and stop working. Is there a way to reroute the temp files to the d drive?
Thanks, Jamie
You can change the TEMP and TMP default paths, as these are environment variables which you can always edit it before launching ContextCapture Engine.
We would recommend that you create a small *.bat that will call the new path for the env. variable + CC Engine:
@echo offSet TMP=D:\TestSET TEMP=D:\TestSET CC_CENTER=C:\Program Files\Bentley\ContextCapture Center"%CC_CENTER%\bin\CCEngine.exe"
