We are required to provide surveys in .pod format.
Our Subcontractor will produce the surveys in .dgn format.
Can this be done?
Can we get file conversion software to convert the .dgn to .pod?
Thnaks
Hi Narciso, I have moved your post to the Reality Modeling community where someone may be able to help you. Descartes might be able to help.
Thank you,
The POD format is a point cloud format. These cannot be converted to DGN, the point cloud (POD file) is attached to the DGN and displayed. Your surveys will be in DGN format with the POD attached.
Thank you Felix
You can easy convert surveys to POD. If you export your surveys as simple XYZ file then attaching it as Point Cloud it will convert it to POD.
