Hello all.
I am having trouble locating rigid concrete pavement deficiencies in my point cloud. I am only able to identify roughly 90% of cracks in my concrete that I can see from my imagery. I am using OpenRoads designer to analyze my point cloud. My question is this: Is ORD powerful enough to do such analysis or should I learn how to use Topodot? I don't know if I am using ORD to its full potential or if it simply is not built to do such analysis.
Thanks all
Is the point cloud classified and with intensity? Also it is no likely that cracks are visible in point cloud because then point density should higher than crack width. ORD has no special tools for PC analysis. You could try Contexcapture crack detector on your dataset as it is trained on concrete defects but photo resolution should be then similar - communities.bentley.com/.../context-insights-detectors-download-page
