https://airworks.io/
I just wanted to share something I stumbled on with the community that we are in the process of testing out for use. It's a company called Airworks that uses AI to process aerial imagery into CAD drawings. If it works out as well as they say it does this will be a huge time and cost saver for getting traditional linework out of a drone flight compared to manual drafting. They also classify the point cloud to generate a ground surface. I know Bentley has some ability to do this as well although from my experience it doesn't do the greatest job. My attempts to get a good ground surface with Bentley tools so far have required lots of trial and error with the settings and then still quite a bit of cleanup to fix points that are missed and add breaklines.
Has anyone else heard about this company or tried it out yet?
