ContextCapture 18 installation in Linux
I tried to work with ContextCapture version 18 (10.18.0.323) in Linux computer.
While my script works fine with CC version16 and CC version17, I get the following error when running with version18:
- "Error 4: Unable to open EPSG support file gcs.csv.  Try setting the GDAL_DATA environment variable to point to the directory containing EPSG csv files.
I checked the GDAL_DATA and it set correctly and the path contains the gcs.csv file
Has anyone encountered this kind of problem?
Doron
