<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>XML/XMLZ formats</title><link>https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/220916/xml-xmlz-formats</link><description>Hello, I perform an AT locally on the desktop CC (version 18), I now want to export the AT&amp;#39;d block to CC cloud processor, which block format should I be using?
 The options are:
 1. XMLZ format
 2.XML format
 3. AT Export XML format
 4. Trend One</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: XML/XMLZ formats</title><link>https://communities.bentley.com/thread/682736?ContentTypeID=1</link><pubDate>Wed, 17 Nov 2021 09:57:05 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:3a7aa4af-51e8-4cec-81af-73a3d798b799</guid><dc:creator>Sylvain Lotteau</dc:creator><description>&lt;p&gt;Hello Brian,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;To use a AT processed with the desktop version in ContextCapture Console for cloud processing, you can work either with the XMLZ or XML format. Please be sure to check the &amp;quot;export automatic tie points&amp;quot; setting.&lt;/p&gt;
&lt;p&gt;Alternatively, from ContextCapture master, you can just submit and choose &amp;quot;process in the cloud&amp;quot;. This will actually export your block information and create a CC cloud Console project from that block.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;The AT export format is a lighter XML file that contains the AT results, but is not used to &amp;quot;exchange blocks&amp;quot;.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;The Trend One XML format is a specific block format for compatility with TrendOne solution.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Thanks&lt;/p&gt;
&lt;p&gt;Sylvain&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
