Can anyone point me to the correct link to download
The links seem to be broken / missing, and it wont let me download it.
thanks
regardsDamien
Hi Oto,
from this thread, looks like you are the one who successfully got the CC viewer to work for your client.
I've created an login account with Bentley, is that sufficient?
But the link to download the CC viewer (that works) is no where to be found.
I don't mind have to login to use the CC viewer, but I don't want to have to install other apps (for CC viewer to work) that I cannot use.
Above is the data set I received (Data folder contains all the Tiles sub folders with *.3mxb data files).
Not sure what is the .xml file is for?
Thank you,
p.sanpitak
Seems you do not have app delivered.
Try this old link for desktop viewer download - https://cs-download.limelight.com/bentley/ht/s/p/rl/dist2/intel/v1020/contextcapturex64/852761ac-303e-11ed-82a9-84a93e817ea2/CCDesktop-10.20.0.4145.x64-en.exe?a=3822&e=1726773329&h=6c6bd4deb728eddfa774092d09624fe3
You are heaven sent...
The link above works and I was able to install the software and got it to work!
Thank you very much again.
