Dear colleagues,
anybody know what the reason of this error?
This message we got after triangulation.
What is your dataset?
Also I see you have set multi-GPU option. If you have only one GPU then disable this option.
To decrypt error code(273965065) you have to register SR.
Do a aerotriangulation without GCPs first and then set GCPs to check if GCPs are consistent.
