On my project I have processed the aerotriangulation of Block 1. An arbitrary measurement taken between parking stalls in the 3D view following the aerotriangulation is approximately 9', which is about what it should be.
However, after submitting and processing a production, the same measurement is now 28.5'. This measurement is about 3x what it should be.
Any idea on what is causing this scaling issue? I have tried processing this with and without ground control points, and cannot get a correctly scaled production in either case.
Which version of Contextcapture you use?
Maybe related to this? - (+) Local Coordinate System (arbitrary units) - ContextCapture | Descartes | Pointools | Orbit Forum - ContextCapture | Descartes | Pointools | Orbit - Bentley Communities
