we created models of the same site on different dates, but after loading into the ContextCapture Editor, these two models have a difference in the Z coordinate.What is the reason for this?Is it possible in the ContextCapture Editor to combine these two models for calculating the difference in volume?
What formats it is?
Does creating new file and using Reference(Coincident World) also have this issue?
Also try to set in coordinate system properties height to Geoid.
two models in 3sm format, then attach to dgn.
where is I need to set coordinate system properties height Geoid?
Under DGN file attached coordinate system properties.
Why these properties are freeze?
Not these, these:
Geographic Coordinate System Dialog (bentley.com)
Geographic Coordinate System Properties Dialog (bentley.com)
Vertical Datum - Matches Datum > Geoid
