Is there a logic to follow in checking the accuracy of Check Points?
Do you just look at the report and compare the XY and Z error, or is there something explaining this procedure?
There is only this outdated document. Maybe latest is delivered with install have to check. Grab while you can.
www.acute3d.com/.../index.html
