How to turn off bumpiness in road surfaces?
See comparision with Pix4D point cloud from same Nadir flight dataset. Pix4D doesn't create bump artifacts all is smooth even that there is less details.
a reconstruction constraint is used only if there is no other reliable data in the area: wherever reliable 3D information can be inferred from input photos, it will override the reconstruction constraint
Recommended workaround: Use of the touchup tool, and remove/fill holes tool could help to resolve the matter.
This workflow unfortunately didn't convince end-user so they chose Pix4D.
