AT large distance to input
Hi.
I recently updated to U18 and I've been hàving issues with AT.
I'm using a drone to map areas and ever since updating many photos end up with wildly wrong positioning. Since I'm using the drone's gps for positioning however, the positioning isn't accurate enough for me to constrain the AT engine. See photos attached
  • Try legacy engine AT preset then it will work as previous.
    U18 uses "new and improved" AT engine but the results sometimes are questionable. Your seems to be related to repeating pattern and also maybe the overlap is too low or photos are blurry.
    If it is Nadir flight reuse calibration from previous 3D flight to improve accuracy.
  • Thanks for the reply.
    I'm using the Matrice 300  drone and Share 102S payload for mapping, which includes 5 24MP sensors with 1 nadir view and 4 obliques. This image set has 90% overlap so I doubt that's the issue.
    I'll try running with the legacy engine however the new engine's performance improvements were part of my reasons for updating so that is a bit disappointing.
    In your experience how much am I missing by not using the new engine? Does update 19 solve this?
  • Better do not upgrade to U19 and skip it with all new milestones status you will get confused more. New engine performance is in part achieved by not relying on GPS tags on AT and use less aligning steps(for example it no longer fixes wrong photo orientation landscape vs portrait)
    If it is multi camera system why don't you set it to be processed as camera rig?
    P.S. You can attach screenshots by clicking PrtScrn key in keyboard and then Ctrl+V copy here. No need to use phone.
Reply
