ContextCapture memory usage
Hi.
I am currently using ContextCapture Desktop edition Update 19 v10.19.0.122 with the following hardware:
- Intel Xeon Gold 6240R 2.4GHz, 24 cores
- NVIDIA Quadro RTX 6000, 24GB GPU
- 128GB (8*16GB) DDR4 RAM
- 2TB PCIe Class 40 Solid State Drive
- Windows 10 Enterprise 20H2
I am currently surprised that only 8% (10GB) of the RAM is used in the production of the point cloud or mesh, although CC reports that the required RAM exceeds 16 GB (without tiling). CPU utilization is around 100% (see screenshot). Vulkan API and multiGPU processing is enabled (benchmark ~300).
Are there any setting options to speed up the calculation?
  • I'm sorry to raise this question again:
    Are there still settings in the ContextCapture Settings or in the Nvidia Control Panel that can be used to make full use of the computer's performance and thus increase the speed of production in ContextCapture?
    In the event that programme-related settings can be made in the Nvidia Control Panel, should these be set for ContextCapture Master or Engine?
