Hello, Hope you are having an amazing day. I have a very important project. The problem is I installed contextcapture center on my windows 10 machine. it opened successfully. However, when I try open ccengine.exe it gives an unable to start application error!! I tried everything to solve it. I installed contextcapture again, tried different versions of it, tried updating my GPU drivers and downgrading them, I even tried it on different windows versions and on windows 11!! I am literally lost, I need to finish the project and this happens!! If someone can help me literally right now it would be so much appreciated!!
Ben Miller said:tensorflow_cc.dll,
So this tells you something.
What GPU and driver you use? Is it game or studio driver?
Can you share a screen capture of the ContextCapture Settings - configuration tab?
Nvidia 980ti with latest game drivers since studio drivers aren't available for it. I tried different versions of drivers from year's old one to latest one
We also have access to 980ti and there are no such issues. But it seems CC has blacklisted this GPU and driver(456.71) so it no longer tries to run AI. So this could be an option to downgrade to this driver and disable AI jobs. Have not found much use of so called "AI" anyway so not a big loss. This driver at least is stable.
Maybe it is possible to disable AI in registry:
Computer\HKEY_CURRENT_USER\SOFTWARE\Bentley\ContextCapture\ContextCapture Desktop\Master
This is what shows in context capture settings. it says it can run ai jobs also if I turn the GPU option in settings on or off it still gives me the error. so what do you sugest me to do now?
