Hello, Hope you are having an amazing day. I have a very important project. The problem is I installed contextcapture center on my windows 10 machine. it opened successfully. However, when I try open ccengine.exe it gives an unable to start application error!! I tried everything to solve it. I installed contextcapture again, tried different versions of it, tried updating my GPU drivers and downgrading them, I even tried it on different windows versions and on windows 11!! I am literally lost, I need to finish the project and this happens!! If someone can help me literally right now it would be so much appreciated!!
I don't have another machine!
I have only 1 a machine available. What should I do now?!
Also tried everything Oto. I didn't now why but nothing worked!!! My project will be lost if I don't do it asap!!!
Just install the older driver and verify that it is installed. Why can't you?
I installed the old driver and verified it is installed. it still gives me the same error!
