Hello, Hope you are having an amazing day. I have a very important project. The problem is I installed contextcapture center on my windows 10 machine. it opened successfully. However, when I try open ccengine.exe it gives an unable to start application error!! I tried everything to solve it. I installed contextcapture again, tried different versions of it, tried updating my GPU drivers and downgrading them, I even tried it on different windows versions and on windows 11!! I am literally lost, I need to finish the project and this happens!! If someone can help me literally right now it would be so much appreciated!!
Install CUDA Toolkit.
Thanks for the suggestion. Did that but still same error!!
Have you tried to install CC U17?
if you mean context capture version 17 then no. is that what you meant?
Yes, try to downgrade. For older versions this GPU and driver was still supported for AI jobs.
