Hello (ContextCapture Update 19,10.19.0.122)
I have been doing Reconstruction from Aerotriangulations of a city, the problem is that in some buildings, the program can not make or construct a complete one, for example:
What can I do? to attack these perturbations?. A similar case is that some buildings are deformed, like this:
I used 3D Polygon for geometry constraints but didn't planarize the building. Sincerely I don't know how to attack these problems.
These are the parameters I use for reconstruction:
Do I need some low-level settings? or some code? to fix these problems?
For Nadir it also helps to reuse 3D calibration - https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/28536/the-model-appears-to-be-curved-instead-of-being-horizontal-after-at
These perturbations(worhmoles) appear where the accuracy of model is lower than thickness of the wall or fence. Easy way is to use Ultra accuracy settings in reconstruction but it is not reasonable for large models.
Also try "high density" option in aeortriangulation it could help to drop some lower accuracy points. "Legacy engine" preset also may work better.
Juan Polanco said:For example, with another program (trial) with the same imagery
STFM softwares are rapidly evolving so better algorithms can give better results in some cases.
