Hi !
I'm aving this error on my 2nd computer's engine while muti-engine computing
my host computer's engine can run it well but 2nd can't do it.
Task monitor says there are 2 engines on run, some task awaiting, some failed task.
I set UNC path good, Job path good, local network good, share setting and authority good(2nd computer can both access and write or change files etc.)
and 2nd engine will feed back error code 【Error: task failed returned : 281026573】 at Areotriangulation computing
and code 【Error: task faile returned : 1】 at Reconstruction computing
what should I do to fix it?
Is there a documents that I can check Error code meaning?
Host computer OS: Windows 10 20H2 19042.186
2nd computer OS: Windows 10 1803 17134.112
Software: ContextCapture Center 4.4.9.516 (both are this version)
thx for reading and helping!
Problem solved, I shutdown Windows defender completely then everything goes will, I hope this may help you.
