Hi all , I have 2 datasets for a plateau and ,I want to generate a mesh .first dataset is nadir taken by Wingtra with Gcps , the second oblique taken by m300 with RTK the total images I have is 16K pcsI have context capture master with license limitation 6000 pic .so what should i do ?
I tried to split plateau to 4 parts so each of part has all nadir and part of oblique , and for each part in first step i use all nadir with gcps then i extend it by oblique , the result is great oblique and nadir merged 100% for each part but the problem is when i try to merge the 4 parts i found there is a shift i always use gcps as constraint.
