How do I rotate when cropping the 3D model using the spatial framework feature?
My subject is in the shape of a rectangle however the cropping box is aligned at an angle so I can not remove all excess and maintain the entirety of my subject.
Thanks.
You need to use retouch workflow then and clip each tile. Cropping tool is missing feature in Contextcapture.
